I know I know, not another buzzing dimmer question....
18 Feb 2009
Lancashire
I have just fitted a wickes dimmer switch to my 7 downlights in my bathroom. The switch itself has a tiny buzz which is fine but there is a louder buzz from the lights/transformers, I have dimmable transformers.
My question is... What actually causes the buzzing? Is it the lights, or the transformers? The lights are fairly low voltage as they are bathroom lights.... Any help would be much appreciated.
Cheers
Si
Dimmer overload
Makes no difference what voltage they are it's the wattage of each lamp
7 down lights at 50W = 350 Watts
What's the rating on the dimmer?
I bet it's 250 Watt
No, actually mate, 7 x 20W = 140W, with a 250W switch.
I asked the question because it's easily livable with (good english!) so if it was the transformers I would leave it, but if I could get dimmable bulbs or a bulb that wouldn't buzz I would weigh that up.
I know it's very hard to diagnose from an email, just wondered what the common things were with dimmers....
Cheers
What rating is/are the transformer(s)?
Is it half decent brand or cheapy?
If you have a transformer for every 20w light they're probably 60's which may explain it- they're underloaded. To dim 12v lighting the transformer should be close to the lamp rating- eg 50W lamp on 60VA transformer, or 4x 20w on 100VA transformer.
I'm pretty sure each light has it's own transformer, I checked that they were dimmable before I bought the switch, but didn't check anything else! It is when I turn them down that they buzz, so I'm sure your right, what's the best thing to do?
Like I say if it's gonna be a big job I can live with the slight buzz, but if it was something I could sort easily and cheaply I would....
Cheers Ben
Thanks everyone for your help, I think I'll stick with the slight buzzing for now until I can warrant spending £100+ on new transformers, and the time to swap them all over!!
I'm sure I'll be back on when that time arises!!
Si
