I have a Feed / Return heating system. I moved a radiator ( upstairs) last night.
After moving, I beld it - and the rad and all rads upstairs now heat fine but down stairs do not heat at all. Do I need to bleed all down statirs rads ?
Also the rad I moved is cold at the botton and hot at top ( even before I moved it) any ideas why this is ? is this sludge / rust in the rad / . I've heard there is an aditive that can be added to the system to help remove this - does anyone have any suggestions/ recomendations which product to get ?
Also, is there any way of knowing which is the lock shield valve on a rad?
None of the valves in my house have plactic covers ( usually hiding the valve) so I can't tell which is which. Is it true the lock shield valve is usually on the left of the rad ?
thanks
thanks
