I've removed the beading from some attic doors because I wanted a clean flush look before I painted them. However some old paint came away with them. Although I've rubbed down the doors ready for the new gloss paint, I can still see where the beading was because the paint layers on either side are thicker. The more I rub them, I just shift the paint edge further away into the middle of the door. I know just putting on undercoat is no solution as it is too thin to fill in the valley where the beading was. Well, at least one coat was. I've not tried more.
I'm clearly doing something wrong here!
If this were a car, with cellulose paint, one solution would be to use a thin smear of cellulose putty to cover up the valley where the beading was. But this putty might react with the gloss paint below. What else can I use?
Otherwise I'll have to take all the doors off and strip them. It's not the weather for doing that now (I can't do that indoors!) and I'm hoping I can avoid this route. Perhaps I should be painting the doors horizontally, would that help?
