Hi all
I think that thanks to this forum I have found a solution to my problem but just need to run it past the experts first
It concerns a ceiling and wall lights. In my lounge I have 2 wall lights and one ceiling light and a double wall switch.
I changed the ceiling light and have cocked up the wall lights somehow - previously one switch did the wall lights and one the ceiling lights - as it should do - however, since I have meddled now one switch does one wall light and one switch does the other wall light and ceiling light together
To explain what I have - in the ceiling are 2 cables each containing 3 wires 1 black one red and one has a green the other an uncoated - I presume these are the earths. I currently have both blacks together - both reds together and both earths together - the ceiling light has a brown, blue and earth - I have connected the brown to the reds the blue to the blacks and earths together. although I have lights working, its as described above.
Having done my homework I have found the picture on the reference page ( //www.diynot.com/forums/viewtopic.php?t=7553 ) the 7th pic down and I think what I have to do is this ( I have a 4 block connecter)
each outside connection gets a black wire - and into these I put the blue and the brown from the light fitting (blue to one black and brown to the other black) - the next block gets both reds and the final block gets the earths
so a 4 way connection block is wired thus if this makes sense:
1: black to brown. 2: red to red 3: earth to earth 4 black to blue
so am I on the right track?
Pete
Pete
