I need to install a new toilet in a out building which is 25m away from manhole which is only 40cm deep. Using the standrd waste pipe the water/waste does not drain to the man hole, I tend to use saniflo, any thoughts?
Yes, a Saniflo is a non starter. You wont get the outlet pipework anywhere near deep enough to protect it from frost, and/or damage. The outlet pipework also needs to be on a steady fall away from the unit, you cant run it to the manhole then rise up to discharge.
If the WC is vital then you need to look at alternatives, i.e. a small packaged pump station.
