- Joined
- 11 Feb 2006
- Messages
- 44
- Reaction score
- 0
- Country
I saw how much my London plumber wanted to charge for removing a radiator so I can paint behind it.
I've read some guides and think I can do it, but need to ask 3 embarrissingly newbie questions first:
1) I looked for a stop cock to the whole house and found something similar to this under the sink:
http://www.plumbworld.co.uk/329-0000?eid=0003-000092
I CANNOT turn the tap despite using loads of penetrant and a rubber hammer, but you see the hexaganal nut thing half way down the picture? - Does that need to be loosened with a spanner first to help turn the tap, or will that just cause the whole thing to fall apart and flood my house?!
2) To remove the radiator, I apparently need to buy a couple of 'adjustable spanners'. Can anyone explain the difference between a) an adjustable spanner, b) pliers, c) wrench, and what is the ideal use of each type of tool.
3) The guides I've read say that I shouldn't trust simply removing a thermostatic valve / controller on the bottom lhs of the radiator because even on the frost setting the valve might not be entirely closed. It suggests buying a 'commonly available dust cap' while doing the work. However, Googling 'radiator dust cap' comes up with nothing useful. What's this all about?! Do I need one to get one and where can I find one in the UK?
Many thanks in advance and sorry for the simplicity of the questions. I hope I'm more competant than I sound.
