Hi all,
After some advice on a bit of a dodgy ceiling.
New house, doing lots of redocorating.
I have just removed some cupboards from a bedroom, and they were hiding a bit of a problem with the ceiling (see picture).
Over a 2' section towards a wall edge, the ceiling rises by around an inch, but the surrounding part of the ceiling all falls back level.
It looks like the width of plaster board, so I first thought something had dropped, but the part circled in red actually looks like an inch if skim.
Both parts of the ceiling 'appear' very solid with no obvious movement when pushed upon, but I'm wondering how easy it will be for a plasterer to correct - or how I explain to him over the phone what the problem is so he knows if he needs anything before he gets here - planning on him skimming the whole room in around a week (he lives not that close so may not be able to get over to have a look first).
Any advice please, is there a term (other than the obvious ), for what has happened here?
Also, using a scraper I can peel away, in several inch secions, the 'paint' (if that's what it is), which is attached to this section of ceiling. It appears fairly well bonded, yet does come of easily if you get under an edge quite nicely. Will the whole ceiling need to be taken back to the plaster, or should a skim bond ok?
Help please, a lot of work in the worst case scenario!
