So back in the good old days, you could buy PIRs with an L1 terminal which you could connect to a switch for an override.
Nowadays they all come with the "feature" that you have to switch power to the light off and on three times to have it come on permanently, then switch it off and leave it for 30 seconds before switching it on again to resume PIR mode.
This, I respectfully submit, is a f**king awful system.
My old-style 500W halogen PIR floodlight, with switched manual override, finally gave up the ghost, so I need a replacement. I'm fine with the new style LED lights, as long as they're bright I really don't care what tech they use. However, I want to retain my existing wiring and switching setup with the replacement. That is - power is permanently supplied to the unit, the light comes on when the PIR is triggered. When I want it on permanently for a time, I turn the switch on. Just like, erm, a light switch. When I'm finished, I turn it off. Just like, erm, a light switch.
Can anybody advise on where I can get a decent PIR floodlight (500W equivalent) with an L1 terminal so I can physically switch the override without having to faff about toggling the switch three times?
Cheers
Cheers
