I wasn't expecting that!
11 Jan 2013
Durham
Needed to drill some holes through joists for a lump of 6mm T & E for a new shower. My trusty flat bits struggle through the 200 year old Douglas fir so thought I'd treat myself to some shiny new bits- these puppies http://www.toolstation.com/shop/Pow.../sd1120/Quad+Cutter+Wood+Drill+Bit+Set/p55369 (I've use the 14mm version very successfully previously).
But then it all went poo- using a 90 degree chuck (so the holes are horizontal so the cables pull through easily and the hole actually is on the centreline) I couldn't hold the drill or the chuck thing still cos the torque needed by the bit as it pulled itself into the wood was too high.
Scratches head.Thinks-these bits have a hex end that look as if they'll fit my impact driver, which is short enough to sit between the joists and drill level. It'll never work but let's give it a go.
So tried it. Very noisy but works very very well- nice clean horizontal hole, no push on the drill needed, the things pull themselves into the wood. No idea how long the bits will last subjected to this abuse but what a result!
Just thought I'd share :)
My trusty flat bits struggle through the 200 year old Douglas fir so thought I'd treat myself to some shiny new bits- these puppies http://www.toolstation.com/shop/Pow.../sd1120/Quad+Cutter+Wood+Drill+Bit+Set/p55369 ... But then it all went poo- using a 90 degree chuck (so the holes are horizontal so the cables pull through easily and the hole actually is on the centreline) I couldn't hold the drill or the chuck thing still cos the torque needed by the bit as it pulled itself into the wood was too high.
IME, that's often the problem with those sorts of bits on hard woods - the 'screwed' part at the tip pulls the drill into the wood far faster than the cutting faces can cut hard wood, with the result you experienced. That type of drill was originally developed for much slower use (hand drills!). Although slower, flat bits are often/usually (again, IME) the best solution in hard wood.
Kind Regards, John
The bosch selfuctters are IMO the best wood bits on the market, they're the perfect combination of flat bit and auger bit, and they just fly through any type of wood. Mine have probably done 1000 holes, hit a few nails each and are still going strong.
