You seem to ask about repairing a lot of boilers but you are apparently not gas registered!
What you describe could be the main PCB and the fan and the display PCB.
Even ignoring the non registered aspect its not a sensible repair for a DIYer.
Tony
Thanks Tony,
you seem always making this remark, I don't repair the gas side at all, I only look at the electrical & electronic side, so a dead boiler got nothing to do with the gas and after I posted the problem today I found the problem, it was the transformer's primary open circuit and that is why it is dead.
Thanks Tony,
You might just possibly be correct on this one occasion.
However, I think that that transformer has a thermal fuse incorporated into the winding as over temp protection.
You can usually see that it has overheated because it half melts the plastic and you can see the uneven surface on the outside of the plastic box.
The problem is that it has usually overheated as a result of an external fault. Sometimes as simple as water on the connector to the display unit or sometimes the fan.
Merely replacing the PCB if you dont know why it overheated risks blowing the new PCB.
Getting BG to do it as a fixed price repair removes most of that risk from you.
Tony
