Hi Guy's,
Thanks for your responses to my previous posting. Unfortunately we still have the same intermittent problem. Boiler banging and screaching, usually when changing from running to standby.
Having had seven rads replaced in the summer I'm wondering if the problem is due to load balancing (or rather lack of it). The return valves on each rad (9 in total) are fully open.
Could it be that the water is returning back to the boiler at too higher a temperature thus causing the HE to overheat?.
To condense properly whilst heating should the boiler be running all the time rather than running - standby - running etc (ours does the later)?.
Also, sorry to be dim, but I note from previous posts that the flow and return differences for this boiler should 20 degrees.....but how do I check the flow and return temps??.
Any advice you could give re these questions would be greatly received, I'm still a little to young for grey hair!!.
