Morning Readers and Seasons Greetings to you all.
I have an Ideal Mini S24 gas Boiler and strange stuff seems to be happening! I last had it serviced in June this year, of course only using the Water Heating bit not the heating until the past few weeks. A new PCB was fitted at that time.
It runs 15 radiators, the end rad (slave??) in the Utility room is the end rad and isn't controllable and isn't turned off.
The thing is, three of the rads, they are the larger ones of the total, only seem to get very hot at the tops, only warm along the bottom. I've bled them to remove the (any) air and it hasn't helped at all.
Additionally, I've noticed, that sometimes the boiler will ignites for about 5 seconds then off again - this will happen for maybe 5 or 6 times in a row then stay on. Otherwise, it works fine, as does the water heating part.
Shouild I worry about this, and do you know what could be the problem please.
Cheers,
Pete
Cheers,
Pete
