My ideal boiler is not igniting. should I switch it off. I switched the immersion heater on to warm the water. What would the best way be to fix my boiler.
The Boiler is an Ideal Classic FF240 - TD 111119 0129 05204 and the Pilot light is not burning. The boiler is not igniting and the pilot does not come on so the water is not getting warm. Its connected to an unvented Thermostore sytem from what I can make out. The boiler was making a noise like ringing noise before it stopped igniting. How old do you think my boiler would be?
How does the immersion heater work. I have switched it on to heat the water as a back up because the boiler being down. How long should I leave it on for. How economical is the immersion heater does it use a lot of extra electricity or not?
Would it be a good idea to get a srvicing contract with British gas? £29 per month to sevice my boiler and central heating system
