Hi all i am a newbie on here & i was wondering if anyone can give me some advice, my Ideal c28 mini boiler keeps dropping pressure on the hot water side, i have checked for leaks but cannot find any, it drops from 1.5 bar to 0 bar in a day, i was wondering if it could be a problem with the DHW flow switch, i have to keep re- pressurising the boiler using the tap on the filling loop, i was thinking that should the boiler once the pressure drops not refill itself via the Domestic cold water inlet ??, also when i press the valve on the expansion tank i get a bit of water coming out, any advice would be most welcome thanks.
