Hi all
The CH pump (Grundos 15-50) has been making strange noises for the past couple of months, gurgling when it starts up, then sounding like the valve is fluttering (vibrating high pitched).
The other day when i tried to run the hot water, the water ran cold, and the boiler didnt start up.
What im wondering is, if the ch pump is not pumping (eg broken), would this stop the hot water from working? I put my hand on it whilst checking the system, and it was really hot, warming up the pipes a few inches either side - with the pipe 6 inches away cold, so it must be kaputt.
I dont know much about heating systems, but i think i remember reading that the tank central heating pipes go through the boiler, then the water goes into the big tank with lagging (cant remember the name) and then the hot water pipes run through the hot water which heats them up.
So my obvious thought is to change the ch pump. Any other ideas would be greatly appreciated.
