Ideal Classic ff280 boiler over heating
10 Mar 2011
Essex
Hi. would anyone be able to advise why our Ideal Classic FF280 boiler overheats everytime the system attempts to heat the hot water. This issue is isolated to the heating of the hot water in that the central heating works with no issues (I have tested both at the same time and in isolation). We had the boiler stat set at approx 4 (which I thought was the recommended level)? thanks.
Are you saying that the overheat stat activates and has to be reset?
If so, I would suspect a flow problem when on hot water only, but there may be a number of reasons. System type would help?
Yes the overheat stat clicks out when heating up the hot water. Regarding the system sorry I should have noted, it is a conventional open vented system.
There are two honeywell motorised valves both of which appear to be opening and closing when requested.
