Guys,
Wonder if you’d be able to offer me some advice,
I have the following CH system:
Ideal Classic FF340
Honeywell 3 port valve
Randall room stat
Randall cylinder stat
Randall 102 mini programmer
I seem to have a problem with my central heating system. The radiators only get slightly warm and the hot water would not be considered as hot as it should. I have tried to work out what may logically be the problem but don’t seem to have achieved too much.
When I switch the programmer from hot water to heat and hot water (and vise versa) the motorized valve does not seem to move at all. I have tried this together with adjusting the room and cylinder stats accordingly but the valve does not seem to make any sound (therefore I don’t believe it is opening or closing as it should). I tried to put it in the manual position but the arm moves freely and there is no resistance.
I ended testing the motorized valve by removing the motor, after doing this I could move the arm into the manual position and there was the resistance I’d expect. Once the motor was removed I switched between hot water and heat and hot water, the motor responded by turning. I believe that the room and cylinder stats work correctly because when I turn them up the pump kicks in and when turned down the pump stops. I’m hoping that you’ll be able to tell me whether this seems to be faulty!!!!
My other problem seems to be related to the heat that the boiler outputs. The feed from the boiler is not so hot as you’d not be able to touch it, it’s only warm verging on hot. I have noticed that the boiler only fires up for a minute or so before shutting down, the pump continues after it has stopped. After about 5 mins the boiler fires up again and the cycle continues. Surely this can’t be right, I suspect that it related to the thermostat on the boiler, however I’ve been told that I’d need to replace the PCB as it’s all integrated. I’m at a loss as to how this can be sorted so any help would be appreciated.
Teggs
Ideal Classic FF340
Randall room stat
Teggs
