Ideal Classic FF40 Boiler not lighting up
23 Dec 2007
Somerset
Hi All,
Got an Ideal Classic FF40 Boiler that doesnt seem to want to light up. I noticed tonight that the water pressure had gone down to around 1/2 bar and the boiler wasnt heating up. I fed some water in the system but the boiler still didnt fire up. The themostat clicks when I move it and the timer seems to be functioning ok.
I've gone through the start up process a few times and I've pressed the reset switch. The reset switch didnt seem to click or anything when I pressed it. The boiler seems to want to start but the pilot light doesnt come on.
I've noticed that the Drayton Zone Valve Actuator (ZA5) was pretty loose on the pipe in the airing cupboard. I've put it back on making sure that the pipework valve section is fitting correctly into the unit but it seems a little loose and doesnt clip in or anything. I cant move any of the black switches on the actuator wether it's on the pipe or off.
Can anyone help me diagnose wether the Actuator is the problem or the boiler?
I'd really appreciate some guidance here, I've tried looking for a manual/guide for the actuator but cant find one.
Can you hear the fan running
Hi, Thanks for your comment. To answer, no I couldnt hear it.
I phoned up a CH Engineer that I've used before and he came around first thing. He had a look around and the fan seems to spin fine if pushed but he said there's an Air Pressure Switch that wasnt working.
He sprayed it with WD40, unplugged and plugged a connection to the fan and tested it and it seems to work fine now. Very impressed!
That does not sound like a very permanent repair.
The fans often become tight and dont start turning.
WD40 should not be used on boilers as its flamable but in any case its only a short term solution to the problem.
I would guess that you are likely to need a new fan soon.
Tony
Tony
Hi Tony, thanks for the comment.
Just to clarify, he sprayed the "Air pressure Switch" not the fan (when the Boiler was off). Does that make a difference?
Cheers
That shows that he is a nupty as spraying an APS would not normally make any difference.
If it were faulty then it needs to be replaced.
I have never sprayed an APS and I dont expect to ever do it either!
Tony
