Thanks I’ll google and take a look. I guess by cylinder cupboard you mean the big tank thing
Ok I’ve just watched a bunch of videos and I think you are spot on. It makes sense watched how they work so I’m going to go check them. Not sure if I can do it I always make a mess. But it doesn’t appear too hard. Just worried about the water spilling everywhere.
Thanks but no need. I removed the head and checked the valve all moving easily and smoothly so I’ve just swapped the head over. Should have been an easy job but took a whole lot of forcing and messing to get it on. Used a 5 way plug for ease as the wiring is a rats nest. It just turned the water on will see if it’s working but I can hear noises in the tank ( cylinder) so I’m guessing it is. Hot water for the first time in ages.
Appreciate the help very much.
