- Joined
- 12 Oct 2022
- Messages
- 6
- Reaction score
- 0
- Country
Hello guys. I have an Ideal Combi 30 boiler. It makes an odd noise and I would love someone to say what it is.
This ONLY happens on heating, never on hot water. WIthin a few seconds of heating been called, the boiler makes a deep, booming vibration a bit like a low didgeridoo being played. If you place you hand on the case, you can feel the noise (Slade record, yes I know!).
I am more curious than anything. Boiler serviced this year after we moved in. Had new gas valve, new sump, new burner at the top and was totally stripped down bar the pump by the chap that serviced it - yes he is gas-safe registered. He also serviced the bypass valve, fitting new pistons, seals, o rings etc. I watched him do it as I am nosey and curious, plus we had a cuppa each and a talk about football.
I would best describe this noise as a low vibration or boom sound. A bit like dragging a very heavy wardrobe across a solid wood floor in the flat above you. It literally lasts a seond or two at most.
As this ONLY happens on heating, (I am purely guessing now) I would have thought it might be the bypass valve as it has to move for heating, or the central heating pump. But it only does it for a seond or so. It might do it 3 or 4 times over an hour when the heating is on.
Any ideas?
Much appreciate any thoughts.
Youtube video not great, but the only time I managed to catch it.
Thanks in advance.
Any ideas?
Thanks in advance.
