Ideal Conceala 2 flush valve (SV93467)
25 Apr 2014
Leeds
Morning all,
I've been to an issue with an Ideal Standard Conceala flush valve (part SV93467). The problem is that both buttons have got increasing stiff to press resulting in the toilet not flushing. Inspection of the flush plate showed there was a crack to the housing of the bellows, this was replaced along with the diaphragms on the valve itself. Unfortunately this hasn't improved the issue. Do any of you have any ideas as to what may be causing it. It there a method of taking these valves apart to service them? It seems like a similar problem to the SV92467 valve that I occasionally see getting excessively difficult to flush.
Any advice appreciated,
Mark
Have you tried changing the bottom seal. They seem to wear away at the edges and may be causing it to stick.
Apologies, yes should have mentioned that the bottom seal was also changed, that had no effect either!
