I have an ideal he30 which from research on here i think has a faulty diverter valve. the reason i am not certain is that the hot water works perfectly and it is the heating that is not great, from what i have read it is usually the other way around.
When the heating is turned on there is a repetitive knocking noise from the diverter valve area.
The heating/burner then turns on and off every few minutes regardless of whether the thermostat is on or off. each time the heating switches on or off the boiler knocks.
Does this sound like the diverter valve, the cartridge or the actuator head?
Or none of the above!?
thanks for your help.
