I have an IDEAL HSAR HE35 COMBI BOILER. This was fitted about 5 years ago and has been giving me problems since 2007. First of all the water heat exchanger had to be replaced. Last year it had another problem wher the 't' light used to come on so frequently, it did not allow heat or hot water to work properly. Luckily I have had a boiler cover with Homeserve and these issues were fixed.
However, now there is now a problem which is giving a major headache. The 'd' light, for domestic hot water comes on very regularly. I had the boiller engineer on site and he changed a filter, but it still has not fixed the problem. The warranty company Homeserve now says there must be a leak in the hot water piping system in the house to the taps that is causing this problem. I have had a plumber come in to look and see if there is a leak and he has checked every pipe that he can access and looked around the house/bathrooms, toilets/kitchen and cannot identify a leak. He says if there is a leak in the hot water pipes then the boiler should stay on domestic hot water all the time not intermittently. Homeserve will not accept this and claims its a leak and until that is fixed they cannot look at the boiler and claims the boiler is fine.
I am stuck....help!
I am stuck....help!
