The LE fault code is displaying, this clears when the reset button is pushed and the boiler fires back to life.
The boiler runs on a timer, and the problem seems to occur at the end of the timer program run cycle. And then will not fire up at its programmed start time in the morning, until the reset button is pushed.
Any help would be appreciated.
PS.. the LE code in the manual indicates a PCB fault, but the system works fine other than cutting out after its daily program cycle and the LE fault code appears.
