- Joined
- 7 Jan 2012
- Messages
- 3
- Reaction score
- 0
- Country
Hi all,
I wonder if someone can help me.
2 days ago we heard banging sounds coming from the boiler and rattling in the pipes, I switched the boiler on and off and it started up ok, with the C boiler status and the burner light flashing and then igniting.
The problem since is that the burner stays on only for about a minute or less and the burner light continuously flashes all the time, after a while (could be minutes or hour) the boiler ignites and follows the same pattern of staying ignited for about a minute and then the flashing burner light again. The pump upstairs stays on all the time while the burner light is flashing so basically never shuts off unless we turn the timer/boiler off completely.
This only happens with hot water, the burner ignites and stays on with the heating on, until the house has warmed up and then switches off, bit goes back to flashing burning light again.
The problem seems to be the hot water side of things.
We had a new zone valve fitted yesterday as well as a new hot water cylinder thermostat, but this hasn't changed anything and the burner light is still flashing continuously as if something is calling for it and only igniting for short periods before returning to flashing.
The hot water is heating up though, but taking longer than normal.
Any ideas please
(Just one other thing to make things more confusing, my partner just ran a bath and the water was hot and the boiler switched on and ignited and has stayed ignited for approx ten minutes but then has gone back to the flashing burner light)
Many thanks for your time and any help you can give.
Any ideas please
