Hello All,
wonder if you could help. our boiler is two yrs old
We keep periodically getting an LF error which from the manual means its a flame error.
We had a similar problem when it was initially installed but this was accompanied by a bubbling sound and "banging" when it did eventually light - this was diagnosed as a blocked condensate trap and problem solved.
We now get the same LF error, but it isnt consistent - ie. we can go a day fine, then wake up in the morning freezing cold as the heating hasnt come on in the morning due to the error. I have managed to catch the problem a couple of times - namely you hear the boiler try to work 3 times and then up comes the LF error. Upon resetting once or twice via the reset button it will generally pick up and work...
I would say the problem happens more when the heating system is still "warm" from the last run (oh and on cold days !!!)....
The fan comes on, the gas valve opens (you can smell the gas in the flu when it doesnt light) and you can even here the electorde clicking...
Thankfully we have a service contract - so far they have been out numerous times and have fitted - electrodes, PCB, gas valve and have also had transco come and fit a new regulator on the gas supply. Beginning to feel sorry for the British gas engineers as they are now scratching there heads trying to work this one out... (oh and the condensate runs clear and fine!)
Next visit we are due a new spark generator and leads...
If anyone from ideal or a.n.other is around who can help with any ideas please let me know !!
James
James
