Hi, Hope you can help...
My boiler threw up an H5 error so I looked it up on the web to find the problem to be with jumpers on the PCB. I turned the boiler off and then on agian and it didn't come back on at all. So I took the PCB out and took it apart.
I cleaned this off and put it back together - boiler worked fine!!!
Then a similar thing happened this evening. if just had a horizontal part of the LED display showing and the boiler light was on permanently. So again I took the PCB apart and found water inside it on the jumpers and also water on the user controls.
So I took off the boilers sealing panel and found water and gunk.
I think its slowly weeping from the return pipe where the pipe enters the heat exchanger.
Is it easy to fix this leak? do I need some new gaskets? I have the installation manual and obviously I'd need to drain the system and heat exchanger. Hopefully it is the joint and not the heat exchanger itself.
Cheers,
Ross
Cheers,
Ross
