ideal icos m3080 blowing
1 Feb 2010
Merseyside
hi
been haveing problem for last week on ideal icos. The problem is ongoing.
when the boiler first went of it was showing fault code to change dryfire thermistor which i changed and the boiler ran for around 30 secs then went of again showing fault code to change ch thermister which i changed along with wiring harness. same thing happend again. (ran for 30 secs approx and went of again showing fault code. changed pcb and worked fine again for 2 minutes. but again gone off. pump also bee changed. could do with some help if any1 has any ideas.
paul
Sounds like a circulation problem, heat not leaving the boiler & dropping it out. Does the boiler refire once its cooled a bit?
