I have an ideal boiler which is now three years old. The mains fuse has blown. In order to check the controls, I disconnected the boiler mains input, replaced the fuse and all of the external controls appeared to work. The programmer came on, turning on the HW and CH controls on the programmer, resulted in calls for heat from the boiler. I reconnected the boiler and the fuse blew again. This time I removed the control wire to the boiler, and replaced it with a link as per the Ideal wiring diagram. The fuse blew again, so I am sure it is a boiler fault. With no mains there is no Fault code, any ideas anyone? I called Ideal, but their customer services will not send anyone out "unless it is warranty work".
