don't normally get involved with breakdowns, but mate has issues with isar he30.
first there was no hot water unless flow restricted at tap, i checked the thermistor and that was fine, he got P-H-E and i replaced it, hot water sorted.
at same time there was issue with a leak, i investigated it, couldn't find anything, cleaned the sump out and checked the sump access plate seal, it was ok. the pressure is also dropping.
went back today, there was a fair bit of water under the main heat exchanger/heat exchanger sump, i checked the seal and it wasn't leaking.
my thoughts are that theres obviously a leak somewhere on the heat exchanger.
anyone with more knowledge of this model of boiler?
cheers.
cheers.
