hi guys,
new to forum but you people have been an absolute god send over the passed few weeks, you guys are great with info so decided to come and join, and you never know, now i have stripped and carried out numerous jobs thanks to you fellas, i may be able to pass on any information i have on these tricky little boilers although i would be quite happy if it just sat there in the background worked! with no problems.
to cut a long story short, boiler is an ideal isar he 30 (i know) fitted under the warmfront scheme about 3 or 4 years ago.
no probs really, apart from replacing the diverter valve once (was really noisy/clunking when it clicked in, but that cured it)
no probs with installation looks like its been done to a high standard.
it all started this xmas eve, woke up, boiler making funny noises, vibrating and leaking water, that's when you guys come! googled it, sounds like frozen condensate pipe, and you were right de frosted, insulated and took off trap and made sure all was clear, inspected sump, nice and clean.
boiler now worked again no funny noises, but no display and a slight dripper. on further googling found aav to be leaking running down onto electrics. fitted new aav and user panel. cured leak but still no display bit the bullet i bought a new pcb (new orange type) now display works but short lived as boiler now not working and coming up with L8 code (fan error) which i found unbelievable but tested out as per manual and all was fine so replaced the fan hurray!! boiler lights up and finally works. now the only fault i have is that during the day it's fine, clicks in clicks out, hot water everything no problem, but when i get up in the morning there is always a pool of water on the worktop. i now leave the bottom cover off and put some kitchen roll under, but not 1 splash during the day, but in a morning it's soaked! can't see where it's coming from i suspect central somewhere because the electrical input connecter (the black plastic multiplug) is wet.
any help would be gratefully received, the boiler all seems to be working fine and no fault codes or anything but as you fellas know all these problems seem to start from some kind of leak. thanks for listening
