HI all i need some help
DHW was only running at a trickle but central heating working fine A week later i came down in the morning to find the boiler dead no lcd display
called british gas engineer out he said there were three faults
Diverter valve leaking and probably stuck in CH position
pcb failed
user control failed he tested to check there was 240 volts to the boiler and removed the diverter valve motor head.
If the pcb has failed will the user control have failed also
In the installation and servicing manual an lcd fault HE is a pcb error but in my case there is no lcd display to indicate any error
What checks can i get my electrician to carry out to establish the pcb and the user contol is faulty as these are expensive parts
pcb failed
