hi, have just changed diverter on Ideal Isar HE 30 thinking i would resolve intermittent hot water issue but no joy. The boiler has had this prob for over a year and im the 3rd engineer to have some fun with it.
Firstly, the DHW heat exchanger was replaced and a scale reducer installed a year ago. Seems sensible and it worked for a couple of months but then the problem came back. The 2nd engineer then made several visits, unstuck the pin on the diverter and installed a line strainer on the return.
Finally, I suggested changing the diverter valve as the return would heat up when the hot tap runs and it had been unstuck on a few occasions and this had resolved the issue. Still the the water runs hott(ish) then cold.
I only noticed after i had changed the valve that the boiler stopped firing every 20/30 secs for 4/5secs(the boiler is a long way from the nearest hot tap). Im wondering if there could be a blockage somewhere in the manifold that connects the DV,HE, pump etc that is causing the stat to to reach temp before water heats ups.
Before I strip the lot out to try and find a blockage has anyone had this prob or any ideas? Cheers.
