Ideal ISAR M30100
4 Dec 2004
Wiltshire
I have had to descale the DHW heat exchanger on my son's boiler, and decided that it may be better to fit a water softener than rely on a Combimate, however I note this in the Installation Instructions:-
Domestic Hot Water
In hard water areas where main water can exceed 200ppm Total Hardness (as defined by BS 7593:1993 Table 2) a scale
reducing device should be fitted into the water boiler cold supply within the requirements of the local water company. The
use of artificially softened water, however, is NOT permitted.
Am I correct in deducing that this prohibits the use of a salt based softener? And if so why would that be?
TIA
I'm sorry, I don't follow you. We had a Combimate as mentioned, but would like to fit a proper softener, however this would appear to be taboo according to these instructions, hence my two questions.
Are you sure the instructions are nor referring to the water in the PRIMARY circuit (i.e. the boiler?) quite often with Aluminium heat exchangers manufacturers are nerous of water softeners due to a possible higher sodium content of the water but for the secondary side (Hot Water) I cannot see a problem, just make sure that the heating filling loop is connected upstream of the softener - I would consult Ideal Technical Dept for clarification on this! ;)
i dont live in hard water area so never seen it used
but in theory you magnet on stop tap would solve problem coming back and i have seen them advetised
No, if you note, the paragraph, (copied from the installation instructions) is headed, Domestic Hot Water. :?: :?: :?:
I shall call Ideal tomorrow.
Thanks guys.
They dont want residual salt in the water. Most makers do allow it and its unlikely to cause any problems even if you do.
You have not told us what you want to achieve with this softener!
Tony
Tony
I would like not to have the DHW plate heat exchanger scale up again.
