hi
ive got an old isar m30100 combi.
i get an l/f error 1-5 times a day! for the last few months
it seems to happen randomly, but have recently noticed that its more likely when boiler is hot/been working hard.
if i happen to be near it when it fails and reset itright away, it fires, goes out and refires 3 times then lf faults this sequence can be repeated 3/4 times, but usually restarts properly by then.
if it fails and its left 2 mins or so (ie cools) it will reset and work for ages!
engineer has recently replaced flame sensor & checked condensate, ive also changed pcb (s/hand) with identical results
fan is often noisy...but has been for years...also loud whining/whistling noise noticeable from outside, again...for years
any advice appreciated
