WE have an Ideal Logic Combi 35 fitted 6 months ago under the 'nest' scheme and so far very happy with it.
When the fitters were here they left us a high level flue extension kit (inc' the flat roof collar ),as we explained that the current 'external wall' the boiler is hung is soon to become an internal wall, as per the approved building reg plans we showed them at the time.
My question is, whilst the instructions clearly show a minimum distance between the air inlet and flue terminal there is no max length the exhaust flue can be. http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/High-Level-Flue-Outlet-Kit.pdf
I have 3, 1m lengths, using either a 2m flue or 3m both comply with the minimum siting dimensions for fanned
flue terminals.
Is there a maximum distance between the air intake & flue outlet?
All the work on the flue will be done by a gas fitter when they install new gas pipes. I ned to know the answer to tell if the builders are telling porkies
flue terminals.
