ideal mexico cutting out
18 Apr 2007
Bristol
hi, can you tell me if i am correct that i have a faulty thermocoupler if my boiler cuts out after about five mins?.. cheers :!: hi, its a balanced flue nat draft burner stays on for five mins then cuts out its hard to light at first as well ! thanks for all your help everybody..
Possibly, along with a few other things.
If it hasn't been serviced recently then i'd advise to. Should cure most problems.
Is it an open flue or balanced flue?
when you say cut's out do you mean pilot light goes out?
Sam
edit that very silly reply, thats what happens when you watch tv at the same time!
Sounds more like overheat. Thermocouple would work or fail totally
It's probably the gas valve.
Just done one with same problem and if it was the thermocoupler it would go out straight away 99/100.
5 MINS off being on do you mean pilot on or pilot and main burner, could just be a partially blocked pilot.
Hear hear for the service engineer!
A lot of engineers ignore the basics.
Dave
