IDEAL MEXICO super CF40/60
8 Mar 2022
Not so super at the moment.
been great, belts out loads of heat and water.
now it's starting to make flame noises. you know like one of those old calor gas heaters when the bottle is running out.
done a clean out with the henry,now it worse. only stay lit with eratic blue flames everywhere then flames out.
if it was a gas BBQ you'd just say its in too much wind.
what d'ya reckon. obys and girls?
I reckon you shouldn’t be tinkering with it and call a gas safe registered engineer. Gas advice in an open forum isn’t permitted as per the forum rules you signed up on today.
Not something that can be safely or accurately diagnosed from behind a screen, and as Chris has said above, Forum Rules do not permit advice on Gas issues.
If you are in the trade, ask to join the Registered Gas Engineers section on here, if not, find someone who is and ask them to come and look. For Your and your Families safety.
thanks for the advise, and completely understand what you are saying. if thats a rule, its a very good one! never even concidered it. as i never concidered doing any work myself. as for a scaffolder my tool box has 3 different size of hammers. just wanted to get right one. got my preferenes!!
As per CBW, don't meddle. When was it last serviced? Are you seeing yellow flames (I bet they are there). If so, it is in a very dangerous condition. Regardless, turn it off immediately and leave off until it is sorted. This category (CF) of appliance is the mist susceptible to seriously dangerous malfunctions when not properly serviced.
Make sure he removes the burner, sweeps the heat exchanger, checks the chimney and spillage check as well as vent is clear. Burner pressure too
