hi, i have the above boiler , problem is the there is no hot water.the heating side works perfect the boiler does not make any noise when hot water is called for . the flow rate of water coming out of the hot tap is very poor would this indicate a scaled up dhw heat exchanger. would the poor flow rate be enough not to trigger the flow sensor hence no clicking sound from the boiler .
cheers
cheers
