Boiler Make: Ideal
Model: Mini C24
Year Make: 2004
Year of Install: Approx mid 2005 at ground floor.
Services: DHW and CH to lounge, 2 bed, 2 bath both in basement.
Hi All,
The issue has become evident since May/June this year. When having a shower in either bathroom, the DHW temp gradually builds to hot then after 30 seconds changes to warm/cold for another 30 seconds then back again. This alternates consistently throughout.
The changes are not as evident via the basin taps but I believe does occur from the tests done.
The only green flashing light on the left suggests 1 second ON, 1 second OFF which I understand is Normal ON.
One thing to note is that we haven't had CH on at all during this period but being curious, I ran the CH this morning to test the shower and the temperature changes no longer seemed to occur. Don't know the relevance or if it was just a once off.
My reading of posts on this site seemed to suggest this was a problem with the DHW Heat Exchanger and/or Temp Probe. I was heading in that direction but then a recent e-mailed response from Ideal suggested the diverter valve could be passing. I’m not sure of the last possibility as I had the Diverter replaced last December along with the DHW Temp Probe and Safety Valve due to a separate issue. Possibility of blockage?
I was hoping some of you in the know about this Ideal model may be experienced to offer any advice to the symptoms experienced to help narrow down the cause.
Thanks for your time.
Daniel
Model: Mini C24
Year Make: 2004
Hi All,
Daniel
