i have an ideal mini c24,the hotwater is working fine but when i put the heating on the boiler ignites and runs 4 about 10 seconds then cuts out,i tried following the fault finding in the manual and this suggested changing the dhw flow switch which i done but this did not fix the problem,when i remove the wiring from the dhw flow switch the heating works fine but cuts out again when i re-connect it.
anyone have any ideas as to what the problem may be?
cheers dave
cheers dave
