Hello folks!
Happy New Year!
1st Post.
I have an 11 year-old Ideal Minimiser FF80 which has been trouble since the get-go 11 years ago. Aluminium Oxide a constant headache, burnt out electrodes, pcb replacement, yada-yada.
Had a new heat exchanger fitted around 18months/2yrs ago. Boiler broke down 2 days ago (30th Dec) and BG engineer tells us that the heat exchanger has failed AGAIN and that basically we need a new boiler.
Some questions..
1) Given that this boiler is well-known to be a lemon, is Ideal (or BG who fitted it 11 years ago and have anually "serviced" it since) liable in any way - the boiler not being "of merchantable quality" or "fit for purpose"??
2) Given that we will be without c/htg and hot water (except by electric convector heaters & immersion heater) for the next 5 days at least, should we expect some compensation from BG as we are on their top "Homecare" package?
3) I hear that Wocester Bosch and Vaillant are the best condensing boilers to go for. Have short-listed the Worcester Bosch Greenstar 40 CDi and the Vaillant ecoTEC plus 637 but I have no idea if one is better than the other - or indeed whether these are a "for like" replacement for my Ideal Minimiser FF80.
4) The system that I have feeds 14 radiators (mainly doubles) in a 4-bed detached house with 2 bathrooms on 3 floors. There is an open-topped expansion tank in the loft and a large copper hot water cylinder in the airing cupboard.
Ideally, I'd like to get rid of the expansion tank in the loft.
I have also picked up whilst trawling the net that there is a possibility that the large copper hot water cylinder should be replaced (can someone confirm this please?)
If, as seems likely, we end up with a new boiler, what shold we have changed to make the system more efficient?
We do not (at present) have any radiator valves on any radiators.
Could we have a separate thermostat/valve to shut off heating to the top floor as it gets very warm up there whilst the botton floor is distinctly chilly.
Lots of questions I know, but any help & advice would be gratefully received.
Happy New Year to all,
Dave
Happy New Year!
1st Post.
Some questions..
Dave
