I have a six year older Ideal Response 80 combi bolier. The hotwater is working fine but when I switch on the central heating the burner does not kick in and therefore the central heating is not working at all
I had a new flow valve fitted early in the summer to resolve hot water intermittently failing to start the burner when the tap was switched on but the hot water has been fine since then.
It's almost as if the bolier knows the heating should be on, it’s just not starting the burner.
Interestingly the ‘Burner On’ light is lit permanently which it never used to be.
I have bled all the radiators.
I have checked the flat thermostat setting and it is fine
I have checked the bolier water pressure and it is fine
Anyone any ideas please? Thanks.
