As above, hot water tank and central heating both with header tanks in the loft. Indirect cylinder. Boiler was getting very noisy and fan changed.
Boiler been off 2 days waiting for part (we were away), now as we wanted hot water quickly on water only the boiler is cycling. Pump is turning. The input pipes at the hot water tank are hot.
Set to water and heating and the boiler doesn't cycle . . . . will wait half an hour and see if the water is getting hot but any ideas what the issue is?
Three position valve? Blockage in piping to hot water tank - all 20 inches or so of it?
Boiler was not cycling before we went away.
Suggestions
Suggestions
