Ideal Standard Dual Flush
21 Jan 2012
Can anyone explain how to replace the dual flush mechanisim on an ideal standard cistern. Thanks Alex
Hi
I think there are two lugs, one either side, just over halway down. Push them in together using finger and thumb and pull upward with other hand.
HTH
On the Conceala cistern, you turn the whole mechanism anticlockwise (as you look at it from the top) about 30 degrees, then it will pull out.
Make sure you isolate the feed first!
