Ideal standard shower bath FOR SALE
10 Aug 2011
Cumbria
I have been left with a new bath after I purchased for a job that got cancelled!
It's a Brand new, full packaged Tempo Arc 170cm Idealform Plus+ Shower bath, left hand
Capacity 195 litres
Location is Kendal, Cumbria
If you have any projects which can use a left hand shower bath, please give me a shout and see if we can do a deal :)
Idealform Plus+ provides all the benefits of Idealform, plus extra reinforcement for peace of mind. Four different layers combine to give these baths exceptional strength and rigidity. The outer shell is vacuumed formed acrylic which is smooth to the touch and luxuriously glossy, easy to clean and resistant to wear and tear. This is then reinforced with Glass Reinforced Polymer and supported by an 18mm encapsulated baseboard to increase it’s strength. Finally the whole bath is coated in an outer colour layer of a Glass Reinforced Polymer resin mix, which creates a stronger bonded product, with a smoother surface and added insulating properties to keep water warmer for longer.
This is the bath only - part number E257601
Them baths vary quiet a lot,can you photo and post the bath bar code ?
photo of the bath also helps,the side panels are important. Have you got any ? are they still available ?
:idea: interested,thou
Bath for sale is Product Stock Code: E257601 -Ideal Standard Tempo Arc 1700mm x 800mm Left Hand Shower Bath (No Tap Hole, IdealForm Plus Bath)
This is a current model and side panel and glass screen are available
Side panel Product Stock Code: E256901 (this you would need to purchase separately) around £40 + VAT
Shower screen Product Stock Code: E2571EO (this you would need to purchase separately) around £115 + VAT
see picture attached of actual bath (packaged) and an identical one installed
