My sister lives in the country in Devon and her electricity supply comes to a pole about 400-500yds from the house in a field. On the pole is a single pole breaker and a fuse (60A) in a ceramic holder. From here the live and neutral go back up the pole and then overhead through trees and over a river to her house.
The problem is that in the winter the branches and the wind cause the wires to briefly touch sometimes which knocks out her electric. This means trailing down the field often in the middle of the night with a torch to replace the fuse wire. Obviously not a great solution. She also suffers from people occasionally turning of the supply as the box just has a triangular key.
The REC want £30k to move the supply closer to the house. Part of the expense is that they would have to put a new transformer in for her closer to her property as the voltage drop with the current arrangement would not meet the spec. (although everything to date works OK).
To improve the situation some thoughts I have had is to replace the wired fuse with something that won't be taken out with just a very short spike (a sort of slow blow) or some kind of remote device that can be reset from the house.
It is not practical really to run an armoured cable through or along the ground.
Any ideas would be appreciated?
