Hi, Can anyone identify this upvc window bead type please ? Total width (with black seal = 33mm, White plastic width = 28mm) I want to replace damaged.
It is very difficult to match upvc beading as designs change continuously. This is an online supplier, you might have some luck with a local window manufacturer.
