Identifying a cable route
30 Jul 2006
Hampshire
I'm considering panelling over a section of a wall which has a surface cable run at present. I will be fitting a line of accent LEDs in the panelling.
Would you consider these 12V accessories in a line would identify a 'safe route' for the mains cable that will be concealed behind them, or should I re-run it in steel conduit or similar?
But if the LED's are located directly above the cable then you would assume there is a cable there and hold off on the drilling :LOL:
What if the LEDs are ever taken out and the cable below remains???? ;)
EDIT:Yeah I know - you'll be able to see the cable through the holes left by the LEDs :LOL:
