Hi guys,
I've removed the ceiling on a single storey extension and found the plasterboard damp, crumbly and covered with mould on the top (roof void) surface. Now that the roofs exposed, I can see the felt has a number of holes and when there is strong wind and sustained rain, water drips from these.
I've measured the pitch at 15°, so after reading other posts on this wonderful site, it seems to me the tiles shouldn't be at such a shallow pitch and that's why the wind can blow the rain in.
Question 1 - Can anyone name the tile?
They have Marley written in the back and are grey flat concrete tiles with a granular surface.
410mm long and 330mm wide (287 wide excluding the interlock).
Extension roof was most likely added in the late 70s.
The most similar tile on the marley website is the "Modern" but they state this is 420mm long.
Question 2 - What's the best fix?
Don't really want to change the tiles as they match the main roof.
Raising the pitch will be a real pain (but is possible if no other solution).
If I strip the roof, should a double layer of felt (if that's the right word) carefully installed with no holes, cope with a bit of water the three/four time a year it'll blow through the tiles?
Question 3 - If you think this is a viable solution, what type/brand of felt would you recommend? If relevant, roof is 6m wide by 2.9m deep.
